Activity Forums Adobe After Effects Issues with Rendering
  • Issues with Rendering
    Posted by Jon Karrde on April 16, 2015 at 1:28 am
    I am working on a Harry Potter themed slideshow for class, and I decided to make it in After Effects so I could recreate the look and feel of the Marauder’s Map from the movies.
    I am also fairly new to Adobe After Effects, and as such this my first time rendering a composition with a lot of effects on it. The effects that I added look fine when scrubbing the timeline and in the RAM preview, but every time I try to render at full resolution, the block dissolve transition effect doesn’t render. However, when I render it at half resolution, it works fine.
    I’ve tried several things to fix this, including exporting it as a lossless .avi file and converting it in Adobe Media Encoder, but the problem still persists. Being new, I’m not sure what I’m doing wrong or what I need to do to fix this, so any help or suggestions will greatly appreciated. Thank you so much.
    Video with issue recorded (forgive me for the dog picture, I’m not sure the people in the real pictures would want me uploading their photos without their permission):
    https://www.youtube.com/watch?v=OyzU07E0DWg&feature=youtu.be
    System Specs:
    Jon Karrde replied 11 years, 5 months ago 2 Members · 2 Replies
  • John Cuevas
    April 17, 2015 at 12:55 pm
    During preview, you are viewing your block transition at half resolution. AE is using half as many pixels. Bump your resolution to “Full”, then adjust your block transition. I’m guessing that a transition height/width of 1 is too small for your final output.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jon Karrde
    April 18, 2015 at 3:14 pm
    You were exactly right. As soon as I bumped up the size on my blocks, the effect worked perfectly when rendered at full resolution. Thank you so much, my deadline was coming up and I was almost hosed by this.
