Activity › Forums › Adobe After Effects › issues with Pro Res (HQ)…
  • issues with Pro Res (HQ)…
    Posted by Eric Johnson on November 5, 2008 at 1:37 am
    Has anyone experience any key/ render problems with Pro Res in AE CS3?
    Gamma shifts, Key noise in general?
    Thanks.
    I’m not real sure what kind of detail is needed for an answer, let me know and I will provide.
    Matt Larson replied 17 years, 10 months ago 2 Members · 1 Reply
  • Matt Larson
    November 6, 2008 at 8:19 pm
    I gave up on using Pro Res in AE months ago! I always render to Uncompressed or Animation when going in and out of AE (any version since AE 7). I’ve found bringing footage in tends to have a gamma issue and the only way I’ve found around it is to use a levels adjustment. Same goes for exporting out of AE.
    If there is a solution I’m all ears, but in the meantime try re-compressing to a lossless format and see if you still have issues.
