Activity › Forums › Adobe Premiere Pro › Issues with Premiere’s multicam audio
  • Issues with Premiere’s multicam audio
    Posted by Kian Mckellar on November 16, 2012 at 10:32 pm
    I’ve set up a multicam edit for the first time with Premiere. The audio I have keeps stopping and starting randomly.
    I’m actually not using the audio from the multicam which is why I am confused. I’ve imported the audio in separately and yet it refuses to play half the time. Basically any audio go nuts in the same sequence as the multicam file.
    Dennis Radeke replied 13 years, 10 months ago 2 Members · 1 Reply
  • Dennis Radeke
    November 18, 2012 at 12:43 am
    Why don’t you sync the clip to your camera 1 clip and see if that helps you out. Another thing is that you could be trying to play the clip while the audio is still conforming – look for a little progress bar in teh lower right side of the Premiere Pro interface.
