Issues with Pre Roll Post and LTFS on OS X
I have just picked up a Quantum tc-l52bn HH LTO-5 drive, ATTO H680, Sonnet Echo Express SE l and the demo of pre-roll post, as I’m sure that’s what I’m going to be using after looking at all options, but I’ve been running into some issues…
When everything is plugged in, OS X can see the ATTO H680 and LTO drive no problem. I can open PRP and format a tape no problem, but even though it is recognised in PRP it doesn’t show up in finder or on the desktop.
I am able to start a new backup on a freshly formatted tape in PRP and backup/retrieve data, but when it comes to adding more data to the tape it’s saying tape is full etc. I can’t recreate the exact errors now as I’ve run out of demo backups and don’t want to purchase until I’ve fixed this first.
This is the log when I format a tape in PRP. I can see that there may be some issues with the permissions in Finder, but was wondering if anyone had come across this before or knows how to fix?
LTFS9015W Setting the locale to ‘en_US.UTF-8’. If this is wrong, please set the LANG environment variable before starting mkltfs.
LTFS15000I Starting mkltfs, QUANTUMLTFS Standalone version 2.2.0, log level 2
LTFS15041I Launched by “/usr/local/bin/mkltfs -f -c –device=0 –rules=size=10M/name=?etadata.xml:*.sqlite –volume-name=SJB_TEST_001”
LTFS15042I This binary is built for Mac OS X
LTFS15043I GCC version is 4.2.1 Compatible Clang Compiler
LTFS17087I Kernel version: Darwin Kernel Version 16.6.0: Fri Apr 14 16:21:16 PDT 2017; root:xnu-3789.60.24~6/RELEASE_X86_64
LTFS15003I Formatting device ‘0’
LTFS15004I LTFS volume blocksize: 524288
LTFS15005I Index partition placement policy: size=10M/name=?etadata.xml:*.sqliteLTFS17085I Plugin: Loading “ltotape” driver
LTFS20013I Drive type is Quantum LTO5, serial number is HU13500FL9, firmware revision is 3210
LTFS9014E Cannot create work directory ‘/Library/Logs/LTFS’: Permission denied
LTFS17160I Maximum device block size is 1048576
LTFS20104W Invalid log-directory path ‘/Library/Logs/LTFS’, setting back to default log-directory
LTFS15049I Checking the medium (load)
LTFS15010I Creating data partition b on SCSI partition 1
LTFS15011I Creating index partition a on SCSI partition 0
LTFS17165I Resetting the medium’s capacity proportion
LTFS11097I Partitioning the medium
LTFS11100I Writing label to partition b
LTFS11278I Writing index to partition b
LTFS11100I Writing label to partition a
LTFS11278I Writing index to partition a
LTFS15013I Volume UUID is: b858977a-bec1-45d9-af2b-eff3d62ca666LTFS15019I Volume capacity is 1434 GB
LTFS15024I Medium formatted successfully
LTFS9015W Setting the locale to ‘en_US.UTF-8’. If this is wrong, please set the LANG environment variable before starting ltfs.
307 LTFS14000I LTFS starting, QUANTUMLTFS Standalone version 2.2.0, log level 2
307 LTFS14058I LTFS Format Specification version 2.2.0
307 LTFS14104I Launched by “/usr/local/bin/ltfs -o volname=LTFS__0__QUANTUM__ULTRIUM 5 -o devname=0 -o eject -o sync_type=unmount /tmp/ltfs0”
307 LTFS14105I This binary is built for Mac OS X
307 LTFS14106I GCC version is 4.2.1 Compatible Clang Compiler
307 LTFS17087I Kernel version: Darwin Kernel Version 16.6.0: Fri Apr 14 16:21:16 PDT 2017; root:xnu-3789.60.24~6/RELEASE_X86_64
307 LTFS14064I Sync type is “unmount”
307 LTFS17085I Plugin: Loading “ltotape” driver
307 LTFS17085I Plugin: Loading “unified” iosched
307 LTFS20013I Drive type is Quantum LTO5, serial number is HU13500FL9, firmware revision is 3210
307 LTFS9014E Cannot create work directory ‘/Library/Logs/LTFS’: Permission denied
307 LTFS17160I Maximum device block size is 1048576
307 LTFS20104W Invalid log-directory path ‘/Library/Logs/LTFS’, setting back to default log-directory
307 LTFS11005I Mounting the volume
307 LTFS17302W Cannot retrieve attribute (Barcode=0x806)
307 LTFS10023I LTFS volume information:
307 LTFS10031I Volume Name : SJB_TEST_001
307 LTFS10024I Volser(Barcode) :
307 LTFS10025I Volume UUID : b858977a-bec1-45d9-af2b-eff3d62ca666
307 LTFS10026I Format Time : 2017-09-02 10:21:26.616166000 BST
307 LTFS10027I Block Size : 524288
307 LTFS10028I Compression : Disabled
307 LTFS10029I Index Partition : ID = a, SCSI Partition = 0, Total Capacity = 36476 MiB, Available Space = 36476 MiB
307 LTFS10030I Data Partition : ID = b, SCSI Partition = 1, Total Capacity = 1367865 MiB, Available Space = 1367865 MiB307 LTFS14111I Initial setup completed successfully
307 LTFS14112I Invoke ‘mount’ command to check the result of final setup
307 LTFS14113I Specified mount point is listed if succeeded
