Activity Forums Maxon Cinema 4D Issues with Move/Selection Tool and Imported Objects
  • Issues with Move/Selection Tool and Imported Objects
    Posted by Alex Last on January 5, 2015 at 11:10 am
    Hi all,
    So I have an issue — when I import .obj files (via dragging them from the Content Browser into the Objects section), they come in alright but the problem is that the Move Tool (and all the other Selection tools, like Rotate and Scale) is way off-screen instead of neatly cradling the object. I have attached a screenshot which demonstrates the problem. You can see the object select with the orange bits around it, but the red, green and blue arrows are way off to the left. This issue is making it quite impossible to work at a close scale.
    Any help would be greatly appreciated,
    Alex
    Alex Last replied 11 years, 8 months ago 2 Members · 2 Replies
  • Brian Jones
    January 5, 2015 at 6:57 pm
    quickest way is to select an object (or objects) and run Mesh/Axis Center/Center Axis To
  • Alex Last
    January 5, 2015 at 11:39 pm
    Thanks!!!!
