Activity Forums Apple Final Cut Pro Issues with FCP Projects after the update (10.0.7)
  • Issues with FCP Projects after the update (10.0.7)
    Posted by Praveen Nu on March 9, 2013 at 12:23 pm
    I’ve created number of Master templates for FCP in Motion5 (For Eg Template01). Template01 has different segments (3-4 options with different camera animations) and i have an FCP project using these generators.
    I have an installer for Master Templates. If i install a praticular project, it will place the .motn files in the generator folder and .motr files in the transition folder and FCP projects in FinalCut Projects Folder. I use to rename CurrentVersion.fcpproject to Template01.fcpproject to identify the project name and while installing, installer program will rename it back to CurrentVersion.fcpproject and put it in the proper folder.
    Everything was working fine for me. But after i updated to FCPX 10.0.7 i am facing lot of issues. Its not showing the FCP projects..But if you check the folder , the files are proper. I use to keep FCPXML to verify the path and everything is proper..when u import that XML everything is working. I dont know what happened after the update..Pls help me.
    Thank you,
    Praveen N U
    http://www.nupraveen.com
    Praveen Nu replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
