Activity › Forums › Apple Final Cut Pro Legacy › Issues with FCP 5 & Compressor 2
  • Issues with FCP 5 & Compressor 2
    Posted by Mr. Sophistication on July 4, 2005 at 5:08 pm
    I’ve had some big problems upgrading from Compressor 1.2 to Compressor 2.
    With Compressor 1.2, I would calcualte my my average bit rate for a MPEG-2 file for a Final Cut Pro 4.5 sequence using export>Quicktime Conversion after I’d rendered out my sequence… there was always consistency with Quicktime Conversion’s calcualted file size and my MPEG-2 exports from Compressor 1.2 (I was using A.Pac for the audio file, so my target MPEG-2 file size was 3.4 GB and audio was about 300-400 Mbs).
    Well, now my company upgraded to Final Cut Studio. We’re using Final Cut Pro 5.0, Compressor 2, & DVD Studio Pro 4. I’ve upgraded QT to 7.0, and using the old “quicktime conversion” file size estimator has proven inconsistent with each export. With a smaller average bit rate, Compressor 2 is exporting larger files. For example, I just exported a sequence that was 101 minutes long at 4.0 mbps average, 7.0 maximum. QT conversion tells me that an MPEG-2 file with this average bit rate will be 2.9 GB, and Compressor 2 tells me that 4.0 mbps average will allow up to 111 minutes of footage on a standard DVD-5. I left this sequence exporting, and the file ended up being 3.8GB, which won’t fit onto a DVD after I’ve added the necessary menus, etc.
    I know this is a long wordy message, but if anyone out there has read this far and has either experienced similiar issues with Compressor 2, or understands the upgrade’s new dynamics, any feedback would be greatly appreciated (this whole FCP Studio upgrade is wreaking havok on my workflow!!!).
    Mr. Sophistication
    Mr. Sophistication replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
