Activity › Forums › Adobe After Effects › Issues with exporting 4K 16:9 composition from AE
Posted by Andrey Khvostenko on May 6, 2015 at 7:36 amHello.
yesterday I’ve tried to export a 4K 16:9 composition from AE.
Here the export settings:
Unfortunately the export resolution is merely 2000 by 2000.
Does anyone know, how to fix this issue?
Thanks a lot!
Andrey Khvostenko replied 11 years, 4 months ago 3 Members · 4 Replies -
Tero Ahlfors
May 6, 2015 at 7:55 amYou missed that little “Settings mismatch” button in the lower left. It would tell you that the resolution restriction for this setting is 2000×2000. You could send this to Adobe Media Encoder and render out an H264 with a proper level for the resolution.
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
Also why are you resizing the render to the same resolution?
Andrey Khvostenko
May 6, 2015 at 8:15 amThank you a lot, Tero!
Sorry for being so blind)
By resizing I was making sure, that the output is really 3840×2160.
Thanks one more time, you just made my day! -
Michael Szalapski
May 6, 2015 at 3:47 pmAlso, I wouldn’t recommend encoding to the QuickTime container with the H.264 codec if you can avoid it. It kinda stinks. There are other, better h.264 options. And I wouldn’t encode h.264 out of AE at all. (It’s so bad, they removed that functionality from current versions.)
I’d recommend rendering to an intermediate codec (QuickTime with the Photo-JPEG codec should be fine) and then use the Adobe Media Encoder to make your h.264
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Andrey Khvostenko
May 6, 2015 at 5:24 pmThank you, Michael! I will reconsider my codec choices (;
There is still a huge gap in my education.
Such comments, however are helpful.
Tnx!
