Activity › Forums › Adobe Encore DVD › Issues with endActions??
Dankelly
January 8, 2007 at 1:49 amHi Jeff,
I got my TS folder and made a copy into my dvd disk for testing. It didnt work! Not sure why, but its behavior was different than the one i got on my computer, even though I set Next/prev NOT to work, on my hardware player it was working… in a wrong way!
After many tests the only way I got it working properly was building the dvd straight from encore, instead of making folders.
-Dan
Jeff Bellune
January 8, 2007 at 2:09 amDVD Folders burned to disc can be unpredictable, depending on which app is used to burn them. Typically, I will burn a disc direct from Encore for a one-off for a client, and then create a disc image from my project for the production burn.
I use Gear Pro to burn the image to disc, although I’ve never had any problem with Encore burning the image. Gear supports burning simultaneously to my multiple burners, and Encore doesn’t yet do that.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
