Activity Forums DaVinci Resolve Issues with audio crossfade DR 16
  • Issues with audio crossfade DR 16
    Posted by Karl Buhl on February 8, 2020 at 8:02 pm
    Hi DaVinci Forum. I am unable to drag a ‘Cross Fade 0dB’ effect between two audio clips to create an audio cross fade. I can drag onto either clip, but not between them.
    I am able to drag the crossfade effect onto the end of the first clip, or onto the start of the second clip. But then I am unable to click ‘Center on edit’ (nothing happens).
    Something appears to be blocking the crossfade between two clips. Both clips are ‘enabled’ and neither is locked.
    Any suggestions appreciated.
    Thank you.
    Karl
    Karl Buhl replied 6 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
