Activity Forums Media 100 Issues with a new install
  • Issues with a new install
    Posted by Noah Wight on April 28, 2016 at 8:15 pm
    So I installed the newest version of Media100 on my new iMac. I’m trying to get the workflow dialed but running into an odd issue. Comp clips that I create in Boris on the video line look like the image below. They render correctly but low quality which I suspect is just a quality settings issue. if i do the same in the title track there is no issue and they look fine. The results are the same regardless of whether 601 4×3 or 1080i. The process is nothing special and I have done it a million times with the same images and process on my other system. Just created new Comp clip in the video timeline and then in Boris added new media> still image and psd doc over solid color track. Apply changes and the top part of the image in the record window is the squished image i’m using with the scrambled artifacts of other images from previous attempts at the bottom. Any ideas?
    Noah Wight
    CBTV Inc/ESProductions
    Crested Butte, CO 81224
    Noah Wight replied 10 years, 4 months ago 1 Member · 1 Reply
  • Noah Wight
    April 28, 2016 at 10:37 pm
    Never mind. Handled. Had to install Prores codecs and get away from Motion Jpeg B.
    Noah Wight
