Activity Forums Compression Techniques Issues when playback H264
  • Issues when playback H264
    Posted by Mat Chevitz on July 13, 2012 at 6:43 am
    I’m having issues when I playback an H264 file, export from AE.
    The film is made of Graphics (source encode in animation) and Video (source encode in Prores)
    I have a 500MB file out from AE in H264, 10Mbits.
    When I play it back in VLC, there are some parts (always the same when I playpack several times) that are very jerky. I first try with QuicktimePro but it was a real pain as it was unreadable correctly.
    The Graphic Part is OK, it’s the video part that is messed up.
    I tried on my macbook pro 4Go RAM 2.8GHZ core 2 duo, and I can’t even read the file as it’s really too jerky.
    The thing is, I tried to export the part that is very jerky alone in AE, and when I playback, no issues.
    So it seems that the problem come from the weight of my video and the power of my computer.
    But I wanted to be sure of that so I share it with you guys.
    Should I first export the graphics in Animation and then do my final export with the others videos in an other software like FCP ?
    Why QTpro can’t read correctly my H264 ?
    Thanks a lot
    Brice
    Editor, MotionDesigner
    http://www.cebri.fr
    MacPro 2×2.8 Ghz Quad-Core Intel Xeon
    8 Go DDR2 FB-DIMM 667 MHz
    Mac OS 10.6.7
    Mat Chevitz replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
