Activity Forums Adobe Premiere Pro Issues when exporting
  • Issues when exporting
    Posted by David Bustamante on August 11, 2009 at 10:11 pm
    The original footage is 25 fps since it was taken with a camera, Is a video mpeg.
    To accommodate and prepare to export the problem is. I tried with 1000 combinations, Both codecs and compressors, From 23.97 fps to 30 fps. Always emphasizing the 25fps that comes in the original video.
    In each of the videos will be exported to reproduce Dan a slight "jump" over the video, The audio is perfect, So frustrating are the "jump" that Dan. To "jump" I mean that any frame skips, Almost imperceptible.
    Sam Green replied 17 years ago 4 Members · 5 Replies
  • Brian Louis
    August 12, 2009 at 12:44 am
    You ought to mention the Brand and model of the Cam that was used,the version of the software used and some system specs, that would people who may try to help a clearer picture of whats going on
  • Vince Becquiot
    August 12, 2009 at 3:56 pm
    Unless you export to the same exact frame rate, you will see this jump.
    At 24p, you are removing frame, and at 29.97 you are repeating some, no way around it.
    If you are seeing this at 25p, then this could have to do with the original footage not being properly supported by Premiere.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • David Bustamante
    August 12, 2009 at 8:59 pm
    It’s a simple Sony CyberShot DSC-W50 photo camera…
  • Brian Louis
    August 13, 2009 at 1:49 am
    The DSC-W50 has two movie modes, mpeg fine(640×480,30fps), mpeg standard(640×480,16fps), You might want to adjust a custom preset to reflect this.
  • Sam Green
    August 14, 2009 at 3:15 pm
    This sounds very much like the problem I am having and recently posted, see:
    Exporting Sequence to H.264. AVCHD footage. by Sam Green on Aug 13, 2009 at 11:05:11 pm
    No-one seems to have any answers to this – what’s the use of a programme you can’t export your footage from? That’s a rhetorical question…
