Activity › Forums › Apple Final Cut Pro Legacy › Issues getting my Mac to create a file acceptible to my PC
Posted by Joshua Weiss on June 26, 2006 at 3:56 pmI have tried almost every single possible codec to export my file from the FCP system. I am trying to use it on a Newtek VT4 system which is a PC. I have 3 VT systems and have not been able to get the Mac to produce an acceptible file. What am I doing wrong?
Shawn Bockoven replied 20 years, 3 months ago 8 Members · 11 Replies -
Walter Biscardi
June 26, 2006 at 4:00 pmGet Flip 4 Mac and make a Window Media file
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Chris Borjis
June 26, 2006 at 4:57 pmlook for an app called mpeg streamclip.
You can easily convert video files quickly and effectively this way.
You will have many more options with this and surely one of them will work.
Joshua Weiss
June 26, 2006 at 5:36 pmRTV is the native file for Newtek VT4. However, it is very friendly to DV files and of course AVI’s. For some reason though, none of the AVI’s that I export from FCP actually work.
Craig Seeman
June 26, 2006 at 6:15 pmAre you exporting as DV/DVCPRO NTSC AVI (or DV PAL AVI as the case may be)? That should work.
Joshua Weiss
June 26, 2006 at 7:54 pmI have tried all the available encodings with the exception of PAL.
Mike Schrengohst
June 26, 2006 at 11:35 pm -
Sean Oneil
June 27, 2006 at 3:11 am[bockos] ”
Change the .mov extension to .dv.”Does that actually work?
Sean
Mike Schrengohst
June 27, 2006 at 4:26 pmI don’t know. Most PC software will read a photojpeg.mov you just have to render.
Mike Schrengohst
http://www.MotionZoneHD.com
