Activity › Forums › Apple Final Cut Pro Legacy › Issues Exporting to 1920×1080 in Compressor
  • Issues Exporting to 1920×1080 in Compressor
    Posted by Amy Lafleche on September 9, 2012 at 5:20 pm
    I am trying to convert video from multiple sources to an mov file with the following settings:
    – Apple Pro Res HQ422
    – uncompressed 10-bit
    – 1920×1080
    When I export it with the original dimensions it works fine, but when I try to change the dimensions to 1920 x 1080 it doesn’t work. I don’t get any errors. It runs through compressor, shows that it’s complete, but there is no file to be found.
    Thoughts on what’s happening?
    Amy Lafleche replied 14 years ago 2 Members · 2 Replies
  • Chris Tompkins
    September 9, 2012 at 7:03 pm
    When you say multiple sources….
    What is your “Sequence” settings?
    Make your sequence the settings you want.
    Export using “Current Settings”
    Done.
    Chris Tompkins
    Video Atlanta LLC
  • Amy Lafleche
    September 9, 2012 at 8:51 pm
    I was able to solve the problem. It turns out the timeline was 1440 x 1080 – I recreated the project in 1920 x 1080 and was able to export.
