Activity Forums Adobe Premiere Pro Issues Exporting in Irregular/LARGE Frame Size
  • Issues Exporting in Irregular/LARGE Frame Size
    Posted by Cara Myers on February 21, 2013 at 4:40 am
    Hi Y’all,
    I’m doing an interesting job where I am creating a video that will be split and projected onto 3 huge 16×9 screens using one video image. (Apparently the company I am contract with has done this before, so asking the event company to change their set up is not an option.) The event company has asked for a Quicktime that is in the dimensions 3840 x 720, so that is what I have set my sequence up in Premiere as.
    However when I try to export, it seems that the widest Quicktime I can export is 2000 wide. When I check the box that says “export with sequence settings” it comes out as 1920 x 360…which appears to maintain the integrity of the aspect ratio but is just smaller than it should be.
    Any ideas??? I’d prefer not to export this and then blow it up in the correct dimensions!
    Cara Myers
    Video Editor/Motion Graphics
    vesperafilms.com
    PLATFORM: Adobe Cs6
    MACHINE: 2 x 2.4 GHz Quad-Core Intel Xeon Mac Pro
    RAM: 14 GB 1066 MHz DDR3 ECC
    GRAPHICS CARD: ATI Radeon HD 5870 1024 MB
    PCI: Black Magic Intensity Pro
    Displays: two 24″ Samsung Syncmaster B2430’s
    VIDEO OUT: 55″ Panasonic TC-P50GT50 55″ Plasma television
    Ivan Myles replied 13 years, 7 months ago 2 Members · 3 Replies
  • Ivan Myles
    February 21, 2013 at 5:57 am
    It depends which codec is selected. QuickTime H.264 seems to be limited to 2000 pixels, but exporting H.264 directly allows 3840×720 at Level 5.1. Alternatively, you can use a different QuickTime codec. I am able to specify 3840×720 with every standard QT codec except the DV’s, DVCPRO’s, and H.264.
  • Cara Myers
    February 21, 2013 at 2:35 pm
    Thank you SO MUCH for your advice and especially for the screenshot. You saved me a lot of stress and troubleshooting! : )
    Cara Myers
    vesperafilms.com
    PLATFORM: Adobe Cs6
  • Ivan Myles
    February 21, 2013 at 5:43 pm
    Happy go help. Good luck with the project.
