Activity Forums Adobe Illustrator Issues creating a proper Vector File and importing to AE
  • Issues creating a proper Vector File and importing to AE
    Posted by Chris Alstrin on January 30, 2013 at 9:37 pm
    I’ve spent almost two days now trying to problem solve this. What I want to do is import a vector file (logo) into AE and create shapes from vector layer.
    This seems simple enough I know. The problem I’m having is whenever I go into AE and create shapes from vector layer the color completely disappears and all I have are lines.
    I’ve tried every possible way to do this and I’m at a complete loss. Here’s what I’m doing:
    I have taken a client’s logo and turned it into a vector based file in Illustrator. I make my changes with the live paint bucket and save the file. I then import it into AE as a composition. As soon as I say Create shapes from vector layer everything goes transparent and all I have are the vector lines.
    My initial thought is I’m doing something wrong in AE. But I create a super basic circle in Illustrator and did the same thing and it works fine. When I convert it in AE the color is still there. So I feel like I’m doing something wrong in AI. Can anyone shine some light on this situation?
    Chris
    Chris Alstrin replied 13 years, 7 months ago 2 Members · 2 Replies
  • Vincent Rosati
    January 31, 2013 at 2:41 am
    Try this query…
    https://forums.creativecow.net/search.php?q=import+after+effects&f%5B%5D=245
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Chris Alstrin
    January 31, 2013 at 4:28 am
    Thanks for the suggestion Vincent but those don’t solve my problem. I tried flattening the image which helped with the color but now I have one image instead of layers.
    Technically I can export each layer separately and import them separately into AE and I will try that next but that defeats the purpose of importing one file with multiple layers.
    Anyone else willing to help out?
    Chris Alstrin
    http://www.alstrinfilms.com
