Activity › Forums › Maxon Cinema 4D › Issues! -Cinema 4D to After Effects
  • Issues! -Cinema 4D to After Effects
    Posted by Chris Arnold on May 13, 2008 at 9:30 pm
    Hey guys, I am having an issue with the integration between After Effects and Cinema. I placed the plugin from the exchange plugins folder into the after effects plugins folder.
    I have set up a scene with a moving camera. I changed the render settings to:
    Composite Project File : After Effects
    3D Data
    Relative
    all being checked.
    Opening up the project file it created, the camera had keyframes created, but the keyframes kept going straight back and had no movement as the movement I had set up in C4D.
    Has anyone else had issues with this? Did I miss a step, or is there some free or commercial plugin I can get that does better then the plugin Maxon gives us?
    Chris Arnold replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
