Activity Forums Apple Final Cut Pro Legacy Issue with pixelated GoPro footage AFTER conversion to PreRes
  • Shane Ross
    January 13, 2017 at 2:34 am
    Your sequence is interlaced…your footage is not. Set FIELD DOMINANCE to NONE.
    Shane
    Little Frog Post
  • Ryan Buller
    January 13, 2017 at 3:36 am
    Went ahead and did that but it’s still looking very interlaced when I play it back in FCP. Also when I closed the project and tried importing the footage to a new sequence with field dominance to none it asked to match the footage and when it did it added the upper dominance back on. Possibly a messed up setting in MPEG Streamclip? Screenshot of settings attached.
    https://i1298.photobucket.com/albums/ag59/ryan_buller1/Screen%20Shot%202017-01-12%20at%207.35.41%20PM_zpszpa0rgef.png
  • Shane Ross
    January 13, 2017 at 2:33 pm
    Your conversion introduced interlacing. It says right there, FIELD DOMINANCE: UPPER FIELD FIRST. Should be none. Personally I wouldn’t use MPEG STREAMCLIP for this…use Compressor. it’ll keep it progressive without needing to change anything.
    Shane
    Little Frog Post
