Activity Forums VEGAS Pro issue with masking in event pan/crop
  • issue with masking in event pan/crop
    Posted by Paul Beller on April 13, 2012 at 9:59 pm
    hi guys!
    please help. is this the way vegas works or i am doing sth wrong:
    i wanna aply an fx to a part of a frame.
    i duplicate a track with my event to be edited.
    so initially i have two identical tracks with two identical events stacked one above the other.
    i apply a mask through the pan/crop window to the upper event
    no antialias, just the mask
    i am getting lines in places where clean border of my mask should be.
    check out the graphic enclosed
    what the hell?
    it is even worse with feathering…
    anybody got a clue for that one, please?
    thanx
    paul
    Paul Beller replied 14 years, 5 months ago 2 Members · 2 Replies
  • Jeff Schroeder
    April 14, 2012 at 2:47 pm
    My guess is that you have other effects applied to both events and it matters if they fall before or after the pan/crop. Look to the top line of your event chain and move fx to the other side of pan/crop. I can explain it in pictures if you need to.
    Jeff
    Windows 7 64-bit, ASUS P6X58D, i7 960 3.20GHz, 24.0GB DDR3, 12TB connected storage
  • Paul Beller
    April 14, 2012 at 5:19 pm
    jeff, thanks a lot for good tip. i tried it out a bit and i see it is a good direction. i don’t have time now to test more but i will 🙂
    as about same fxs on both events – look: i can’t have trhe same fx on both. this is why i am masking to apply sth different to the upper event. anyway, thanx for a good advice, i hope this will be the one i need. 🙂
    p.
