Activity › Forums › Adobe After Effects › Issue with element 3D Mask Extrude
  • Issue with element 3D Mask Extrude
    Posted by Diego Riverol on April 14, 2021 at 2:06 am
    Hi, im having a problem with an extrude mask.
    The thing is that i want to modify the mask, but the 3D objects aligns automatically to the center.
    This makes it imposible to create custom path animations without the model being moved in the oposite direction. The same happends in any direction you move it, it moves the opposite.
    I checked that this is because of element 3D alignment, under the Transform section (it has center, righf, left, bottom and top).
    It doesnt offer a “None” alignment. How can i solve this?
    Thank you
    Diego Riverol replied 5 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
