Activity Forums Adobe After Effects Issue with a shadow effect
  • Issue with a shadow effect
    Posted by Jeff Bonano on July 29, 2009 at 7:19 pm
    Here’s an example of what I’ve got:
    Here’s what I’m trying to do:
    The spot light is just off to the side of the comp in front of the camera, the red and blue are rotating spotlights that have been placed behind the camera. What I’m trying to do now is have a shadow of a cop car to the lower right portion that is only created with shadows from the red and blue lights, but not the spot light up front.
    I tried making a mask from a solid layer and turned on cast shadows. to prevent it from actually being seen, I found I have to put the layer behind the camera but in front of the lights. When I’m in active camera mode, the layer casts no shadows. I also tried selecting cast shadows only and putting the layer in front of the camera, but nothing happens. Lastly, I notice the first tactic does work when I set active camera to front view, but this doesn’t help me when It’s time to render. Does anyone have any suggestions as to what I forgot to do in order to accomplish this simple effect?
    Jeff Bonano
    http://www.bonanoproductions.com
    Scott Novasic replied 16 years, 9 months ago 2 Members · 1 Reply
  • Scott Novasic
    July 30, 2009 at 12:10 am
    when all else fails, manually do it. Im not totally sure what look your going for. A red light or a blue light shining on the cutout of a cop car will still cast a black shadow. Take your outline of the cop car and simply select the plug in drop shadow and multiply. Make sure your cutout is pure white. place it where you want it either in the pre-comp so it moves with the camera or track it manually for more of a stylistic look. Perfect and photoreal is not always the best way to go….
    good luck
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
