Issue with 3D Room Wall
Hey everybody
I’m working on a video in AE where there is a wall and floor with 3d perspectives that repeat using Motion Tile.
I have these two layers as children to a Control NULL Object that I use to control their position.
The wall and floor are to move to the left and I have created other objects that are supposed to be parts of this “room”.
The Issue I have is As the objects move to the left with the wall and the floor layers, they seem to move faster than the wall and the floor. They are not moving at the same speed.
The problem with this is that It appears as if the layers in the scene are gliding over the wall and floor while the wall and floor move on slowly.
Is there any way to fix this to where the objects in the room move at the same speed that the wall and the floor move? Or vice versa?
Let me know if you can help. Thanks
