Activity Forums Adobe After Effects Issue with 3D object animated along a motion path
  • Issue with 3D object animated along a motion path
    Posted by Kieren Smith on November 7, 2012 at 12:53 am
    Hi Guys,
    I’ve been having this issue for a long while now and I haven’t been able to figure out how to fix it.
    It involves a 3d object oriented along a motion path… As seen in the video below, the object flips when it passes a keyframe I’m only keyframing the position not the rotation but it seems EVERYTIME I create this kind of an effect it does this… Any ideas of how to fix this flip?.. Also when ever you stop on a keyframe, the object is rotated some how and is barely visible…
    Here is the Video:
    https://reels.creativecow.net/film/3d-orient-to-path-motion-path-test
    Here is the Project file for the video so you can see my setup:
    4923_3dmotionpathtest.aep.zip
    Kieren Smith replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
