Activity Forums Adobe Premiere Pro Issue sending sequence from Premiere Pro to SpeedGrade CS6
  • Issue sending sequence from Premiere Pro to SpeedGrade CS6
    Posted by Brian Horvath on May 22, 2012 at 1:20 am
    I have a 4Tb FW800 drive connected to a MacPro 1,1 (10.7.4) which is running Premiere Pro, Speedgrade CS6. I was cutting a multi-cam DV sequence which is roughly 90 min. I wanted to send this to SG to color correct and then output to final. When asked where to save the SG project, I chose the FW drive because I didn’t have enough space on the main HD. PP took about 3 hours to transcode, and now I end up with almost 500G of DPX files. SpeedGrade doesn’t open the file created out of PP properly and I can’t figure why. Could this be because all the DPX now lives on the FW drive and FW800 isn’t fast enough? Is there a way to send a project to SG without that long transcode?
    I tried to open the SG project by double-clicking the project file, but the video won’t open.
    Perhaps this is a codec issue?
    Maybe someone can suggest a better workflow?
    Brian Horvath replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
