Activity Forums Maxon Cinema 4D Issue saving/exporting Adobe After Effects Compositing file from Cinema 4D.
  • Issue saving/exporting Adobe After Effects Compositing file from Cinema 4D.
    Posted by Javier Lopez on February 4, 2015 at 11:43 pm
    Hello,
    I have an issue with the “.aec” saved from Cinema 4D, when I try to import the file into After Effects it gives me an error message, also the .aec file has a yellow warning sign as an icon on it, the data that I am trying to export/import is from a light animated over a spline, I had set up the scene correctly with render setting including the save the AE file, also set the frames that contains the motion, I am using Cinema 4D R16 and Adobe After Effects CC2014 on mac, any advise please?.
    Thanks.
    Cristi Dinu replied 11 years, 6 months ago 3 Members · 2 Replies
  • Cassius Marques
    February 5, 2015 at 1:38 pm
    You should import the .c4d file into AE and use cineware to extract things… I think the route you’re going is obsolete with those versions.
  • Cristi Dinu
    March 11, 2015 at 10:46 am
    You need to install a certain plugin in the Adobe After Effects plugin folder in order for it to see and import your AEC file.
    More information here:
    https://www.maxon.net/support/updates/plugins.html
