Activity Forums Apple Final Cut Pro Legacy Issue of QT settings for DV capture
  • Issue of QT settings for DV capture
    Posted by Philippe Muller on August 1, 2013 at 5:45 pm
    I hope to find some help from your part because I’m stuck with a dvcam capture problem.
    My FCP capture settings are DV PAL 48 khz (I’m in France) and when I open the capture window, I get this message:
    ‘an error occured during the QuickTime settings for the capture parameters. Quit FCP and check your hardware configuration’
    the deck controls are OK but I have of course no preview.
    I’ve changed the firewire cable, downgraded QT to 7.6.4 (with Pacifiste), removed the FCP and QT preferencies.
    No effect. The problem remains the same.
    Nevertheless I think I’ve done this in the past with success.
    MacPro OS 10.5.8
    FCP 7.0.3
    deck SONY DSR 20P (miniDV and DVCAM)
    Could you help me ? I would be very gratefull
    Regards
    Philippe Muller
    Philippe Muller replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
