Activity › Forums › Apple Final Cut Pro Legacy › Issue Mastering Combine 4:3 and 16:9 formats
  • Issue Mastering Combine 4:3 and 16:9 formats
    Posted by Tiffany Tennison on May 16, 2008 at 3:04 pm
    I am trying to master a timeline in FCP that combines 4:3 and 16:9 footage all on a 4:3 letterboxed timeline.
    I have to make a quicktime movie file and master off of an older apple (g4) because I have edited the entire project on my laptop. This needs to be mastered to a Beta SP.
    The problem is the 4:3 footage is jittering whenever it is recorded. When I am watching it on the computer as it is mastering the footage both formats are playing very smoothly like it is suppose to. However when I watch the monitor that is coming off the deck the footage is very jittery (almost as though it is skipping frames or something.)
    When I play the tape back it has recorded jittery.
    Does anyone know how to fix this? Is this a result of make a QT movie? How do I get around this. I have a G5 that is being updated to the new version of FCP, if I can get it updated then hopefully I can skip the step of making the QT movie, and master straight from the original timeline, but I am not sure that is going to solve the problem. Any insight into this would be great!!!
    I need help ASAP, the project is due today.
    Tiffany
    Andy Mees replied 18 years, 4 months ago 3 Members · 2 Replies
  • Rafael Amador
    May 16, 2008 at 4:09 pm
    Hi Tiffany,
    how are you pringting your clip to video?
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Andy Mees
    May 16, 2008 at 4:36 pm
    sounds symptomatic of a field order issue whereby the jittering footage is being rendered with a reversed field order. to overcome this check these clips in your timeline … open each affected clip into the viewer by double clicking it in the timeline, check under the filters tab and see if there is a Shift Fields filter applied: if it is already there then remove or disable it … if it is not there then add it it (Filters > Video Effects > Video > Shift Fields). Now re-render and see if the jittering issue is fixed.
    hope it helps
    Andy
