Activity Forums Adobe Premiere Pro issue exporting sequence with Immersive video transition
  • issue exporting sequence with Immersive video transition
    Posted by Rick Neely on October 2, 2019 at 2:54 pm
    Hey folks,
    question- made a sequence in Premiere Pro and added a couple Immersive Video transistions (Mobius Zoom I think).
    After full render (and CUDA cores enabled in video card). Sequence plays fine in Premiere.
    However, when I send to Media Encoder to export to MP4 (H.264), the rendered file shows a red strip stating ‘This effect requires GPU acceleration’ at the immersive transition points.
    I’m confused- entire video was rendered effects (green stripe across) and exported. I assume the effect was threrefore processed in effect mixdown.
    What am I missing? Anyone?
    Rick
    Todd Perchert replied 5 years, 10 months ago 5 Members · 4 Replies
  • Paul Nicholson
    October 2, 2019 at 10:02 pm
    I have read that Adobe Media Encoder is FAULTY and your best settings for export are these:
    Select GPU Acceleration
    Select Render Audio when Rendering Video (then press Enter and wait for Render to complete)
    Select Use Maximum Render Quality
    and most importantly
    Select Export NOT Queue.
  • Jon Doughtie
    October 3, 2019 at 6:16 pm
    More information would be good, like computer specs, OS, version of Adobe CC, etc. Otherwise it’s all pure guesswork.
    Max Render Quality is primarily for renders of re-sized content, otherwise it mostly just adds time to the render.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Darryn Rogers
    October 21, 2020 at 4:24 am
    Hi Rick
    I guess you’ve probably solved this one or given up on it by now but I’ll leave this here for the record.
    I was having a very similar problem With After Effects and Media Encoder. Immersive video effects were rendering fine in the AE timeline but rendering out of Media Encoder resulted in the same red warning bar. Which is weird because I had rendered the exact same project a few days earlier out of Media Encoder with no issue.
    I finally managed to get it working by uninstalling then re-installing Media Encoder through the Creative Cloud app. I expect that doing this will also fix the problem rendering out of Premiere, although I haven’t tested it.
  • Todd Perchert
    October 21, 2020 at 3:17 pm
    Not sure I like this new COW format where old stuff can come to the top when someone comments on it…. but, since it’s here, when you are in your AME Export settings, switch between CBR, VBR 1-pass, and VBR 2-pass, and check your Performance drop down to see what happens as you switch. On my Win10 system at home, it goes to Software Encoding when selecting 2-pass VBR, but CBR and 1-pass both can have Hardware Encoding selected. I’m betting this is where the issue is coming from, trying to use VBR 2-pass.
    TC
