Activity › Forums › Broadcasting › Isolation Transformer/Surge Suppressor
Posted by Brent Ingroum on February 24, 2010 at 7:41 pmI was just wondering if anyone had any recommendations on a rackmount power strip with Isolation transformers? Also, voltage regulation is a plus.
BrentTom Meegan replied 16 years, 7 months ago 4 Members · 5 Replies -
Bob Zelin
February 25, 2010 at 3:40 amHere in Florida, you have to be nuts to work without surge supressors. I use big expensive APC UPS units on EVERYTHING, because of the power hits – especially in the summertime. I have seen countless units – big and small, go up in smoke. There is no such thing as a “good value” surge supressor, when you take a lightning hit, and you lose the media on your drives. All of sudden – $500 – $600 for your entire system looks REAL CHEAP !
Bob zelin
Brent Ingroum
February 25, 2010 at 3:46 pmBob,
Thanks for your reply. I want to point out that I’m not looking for “cheap.” I was just wondering if anyone had any suggestions for a good rackmount unit.
Thanks again,
Brent -
Bob Zelin
February 26, 2010 at 5:10 amI use APC Smart UPS 1500RM 2U. About $600
IF you don’t need the UPS, any of the Middle Atlantic PD series, or Furman series work just fine for surge supression. And if you can’t afford these, a cheapie Home Depot strip with some sort of spike protector is much better than straight into the wall.
I’ve seen the cheapies work on a tranformer that blew – they saved the equipment.
Bob Zelin
Maurice Jansen
February 27, 2010 at 6:44 pmhi there
we use Watford Control for power conditioning. in combination with a UPS.
they have a lot of stuff not mainstream but good.https://www.watfordcontrol.co.uk/
greet
MauricePeople saying they don’t make mistake’s often make nothing at all!
Tom Meegan
March 7, 2010 at 10:30 am
