Activity Forums Adobe After Effects Isolation Room with padded wall
  • Isolation Room with padded wall
    Posted by Wollie on June 3, 2006 at 6:36 pm
    Hi to all, I’m trying to create a 3d room with AE 7.0 Pro, and I’m not really sure how to do it. I mean, the room itself it’s quite simple, but to add deepness to the scene, I want to make the wall padded. Someone could give me an hint or two?
    Filip Vandueren replied 20 years, 3 months ago 3 Members · 3 Replies
  • Filip Vandueren
    June 3, 2006 at 11:31 pm
    Well, after effects’ layers will always be flat, so even if you use a texture that fakes the lighting of the padded surface, at a steep enough angle, the illusion will always break.
    If you can’t live with that, you’ll have to resort to a true 3d program, or use Invigorator to model a 3d environment within After Effects.
  • Jonathan Miller
    June 4, 2006 at 6:08 am
    Filip’s right on the money here.
    AE is limited here, but you can always trick the viewers into believing there’s more there than there really is. Have you tried enabling Depth of Field on your camera? It can make your scene look more realistic and could make it look deeper. Suddenly, not everything will be in focus, and the wall at the end of the room could look further away and its textures won’t have to be as precise since they will not be razor sharp.
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
    Currently producing these popular podcasts:
  • Filip Vandueren
    June 4, 2006 at 11:48 pm
    Just for the hell of it, I decided to make the basis for a padded wall texture in AE:
    here’s the project-file:
    padded_texture.aep
