Activity › Forums › Adobe After Effects › Isolating pure primary colors without white?
  • Isolating pure primary colors without white?
    Posted by Markp on March 1, 2006 at 11:47 am
    I have been given a 3D-rendered sequence containing only elements of:
    Pure Red 255,0,0
    Pure Green 0,255,0
    Pure Blue 0,0,255
    Pure White 255,255,255
    I am trying to isolate these four different values to use as four separate mattes.
    Normally I would work with separate B/W mattes for each element I needed to matte, but I have been given this sequence from an outside source.
    The trouble is that white contains all the colors, so whether I choose R, G, or B, white is included. Ironically, keying does not give pristine results
    Is there a channel effect I can apply which will isolate only pure colors of either R,G, B, or white?
    Ryan Hill replied 20 years, 7 months ago 5 Members · 12 Replies
  • 12 Replies
  • Aharon Rabinowitz
    March 1, 2006 at 2:05 pm
    – Have you tried a Luma Key instead of a chroma Key? Luma keys are designed to pull out blacks and whites.
    – Also Perhaps you can use the “Change to color” effect to change it to a color you can key out with keylight.
    Just suggestions – no idea if they’ll work…
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Chris Smith
    March 1, 2006 at 2:41 pm
    If it’s what I think it is, have them re-render it properly with the 3 primaries plus black. I take it it’s a 3D pass to get 3 channels of data in one render. Like a normal map, or a lighting map.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Markp
    March 1, 2006 at 2:47 pm
    Thanks for the suggestions… tried the luma key but it’s very crude… looking for a better degree of precision than that.
    Surprised AE can’t make the differentiation, though I appreciate that White = 100%R+G+B (!)
    Think it’ll just be easier to request the channels as seperate sequences. Live & learn…
  • Steve Roberts
    March 1, 2006 at 3:32 pm
    Just a thought: if you take out the R, then the G, then the B, what’s left?
  • Markp
    March 1, 2006 at 4:52 pm
    Chris, you’re completely correct.
    I guess they were trying for four different sets of data in one pass….
    Pleased to know it couldn’t be done with white & that I wasn’t missing some channel function
    Cheers –
    M
  • Aharon Rabinowitz
    March 1, 2006 at 5:30 pm
    I totally missed the 3D nature of your render. Well, good to know chris was on top of it.
    Good luck.
    Aharon Rabinowitz
  • Chris Smith
    March 1, 2006 at 5:56 pm
    You could use the alpha channel as the 4th channel. If you can get your 3d program to write data to that channel that is not transparency. Then when you import it to AE make sure the alpha channel option is set to ‘none’.
    However it seems like a real bear to do. I would just deal with the 3 channels at a time.
    Or you can look at Open EXR which has generally unlimited channels. AE 7 now uses Open EXR, but I’m very unfamiliar with how to implement all the channels in AE. In Nuke for example it sees Open EXR very similar to a multi track audio tape. It allows you to split the tracks and do with them what you please. This way you can keep many, many passes from 3D all self contained in one file.
    Chris Smith
  • Markp
    March 1, 2006 at 7:27 pm
    In response to Steve’s post –
    If I take out R, G & B I’m left with black.
  • Ryan Hill
    March 2, 2006 at 5:56 pm
    If it really contained only “pure” colours, then I don’t understand why it couldn’t be keyed cleanly. Did the composition match the dimensions of the file? Are there mixed colours, like red and blue overlap to make purple?
  • Ryan Hill
    March 2, 2006 at 6:00 pm
    He may have meant use RGB to mask out everything that isn’t white.
