Activity Forums AJA Video Systems Is Your Easy Setup for Kona ProRes NTSC 8-bit or 10-bit?
  • Is Your Easy Setup for Kona ProRes NTSC 8-bit or 10-bit?
    Posted by Sean Oneil on May 30, 2007 at 9:00 pm
    Decklink user here. The Blackmagic ProRes NTSC Easy Setup uses 8-bit capture and playback. This appears to be a mistake since ProRes records at 10-bit.
    Can any of you Kona users check and see what your Easy Setup is? Look under Audio Video Settings and check “Video Playback” and “Capture Preset”. I want to see if this was a mistake Blackmagic made or if ProRes actually does record NTSC at 8-bit only.
    Thanks.
    Sean Oneil replied 19 years, 3 months ago 2 Members · 2 Replies
  • Szumlins
    June 1, 2007 at 1:08 am
    The easy setups for the Kona cards correctly use 10-bit.
    -Mike
  • Sean Oneil
    June 1, 2007 at 5:03 pm
    Thanks. Someone at Blackmagic got back to me. I guess they screwed up and made all their ProRes Easy Setups 8-bit.
