Activity › Forums › Compression Techniques › Is true, interlaced pulldown possible with ffmpeg/ffmbc? (i.e. 23.98p to 29.97i framerate conversion)
  • Is true, interlaced pulldown possible with ffmpeg/ffmbc? (i.e. 23.98p to 29.97i framerate conversion)
    Posted by Mel Matsuoka on September 11, 2013 at 4:21 am
    My fingers are numb from playing around with all the crazy undocumented ffmpeg and ffmbc options, namely interlacing and pulldown options.
    I need to write a script that will convert a 23.98 ProRes Quicktime to a 29.97 ProRes Quicktime, with interlaced, upper-field first pulldown. I’ve built in in-house tool that does these types of conversion via the Apple Compressor commandline interface. But I’m trying to eliminate my dependence on Compressor/Qmaster for encoding tasks, so it’d be nice if I coould do this using ffmpeg or ffmbc.
    But so far, I cant figure out how to introduce proper interlaced pulldown into 29.97i target files using either tool. FFmbc seems to have “-pulldown 3:2” switch, but after an hour of experimentation and intense Googlin’, it appears to me that this flag only works for MPEG-2 files. Since my main output format is ProRes, this is a non-starter for me.
    Is there some esoteric flag, or combination of techniques which I can use to do proper 23.98-to-29.97 conversions using ffmbc or ffmpeg?
    Mel Matsuoka replied 13 years ago 2 Members · 2 Replies
  • Reuben Martin
    September 27, 2013 at 10:21 pm
    For interlaced prores encoding add “-flags +ildct” (should work with kostya preres encoder, not sure about the others) Not very well documented at all.
    The telecine filter is documented here: https://ffmpeg.org/ffmpeg-filters.html#telecine
  • Mel Matsuoka
    September 28, 2013 at 2:22 am
    Thanks Reuben…I swear I Google’d the crap for “ffmpeg pulldown”, not to mention searched the ffmpeg/ffmbc manpages but I never found the information in your link until you provided it. For as awesome as the tool is, ffmpeg has the some of the worst/haphazard documentation I’ve ever seen,
