Activity › Forums › Adobe After Effects › is this windows’ fault?
  • is this windows’ fault?
    Posted by Johan Hoogendoorn on August 26, 2008 at 6:29 pm
    sometimes, when I render, slight pieces of footage are not in sync with the music; we’re talking mili-secends
    frustrating, when you’re making videoclips
    comp is 960×540
    based on fine animation-movs
    wav under it
    I use windows
    maybe that´s the problem, I suspect QT windows
    regards,
    Johan
    Todd Morgan replied 18 years, 1 month ago 2 Members · 1 Reply
  • Todd Morgan
    August 27, 2008 at 10:55 pm
    Need more info to help you with your problem:
    – what is frame rate of video
    – what is frame rate of audio
    – what is frame rate of comp
