Activity › Forums › Panasonic Cameras › Is this thing real?
Is this thing real?
Posted by Jeremy Kromberg on June 16, 2006 at 12:48 amhttps://www.spec-comm.com/scpci-p2.php
I found this at dvxuser.
Mediaman Nc replied 20 years, 2 months ago 6 Members · 8 Replies -
Barry Green
June 16, 2006 at 3:13 amSure. Why do you ask?
These things work, the only limitation is that you have to have access to the back of the computer…
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db) -
Mike Schrengohst
June 16, 2006 at 4:54 amWow, that is cool, I may need to learn Edius a little better!
Mike Schrengohst
http://www.MotionZoneHD.com -
Jeremy Kromberg
June 16, 2006 at 5:04 amWow! I thought the only options were a G4 Laptop ($1000) a P2 Store ($1600) or one of those 5 slot Panasonic card readers that was like ($2500). So if I used one of these to copy P2 cards to a PC would I be able to copy them to a FW drive and then bring that drive to a Mac with FCP for editing? It seems to good to be true. Thanks for the reply. J.
David S.
June 16, 2006 at 3:39 pmJerry:
You should confirm that this PCI card will work with a G5 desktop Mac first.
Not certain it will.
Barry Green
June 16, 2006 at 5:42 pm[Jeremy Kromberg] “So if I used one of these to copy P2 cards to a PC would I be able to copy them to a FW drive and then bring that drive to a Mac with FCP for editing? It seems to good to be true.”
Yes you could do exactly that. We’ve been using a PC laptop to copy the cards over to FAT32 FW drives, and then edit on the Mac. Works just fine.
Having a $70 card reader instead of a $4,000 deck is one of the advantages of the P2 system. P2 is designed around leveraging cheap, universal, existing computer hardware instead of proprietary video hardware. You can use a $399 PC laptop in the field to offload cards instead of a $2500 slot reader as well.
Jeremy Kromberg
June 16, 2006 at 6:01 pmThanks Barry, I think we just saved enough $$$ to get the AJA HD10AVA or a bigger Chromatte screen. Thanks for the info and I cant wait for the HVX book. Jeremy
Aaron Wells
June 17, 2006 at 10:41 pmI emailed Specialized Communications and was told it was not compatible with the G5 (or any Mac for that matter).
Buy the ticket, take the ride.
Mediaman Nc
June 30, 2006 at 7:03 amHi Barry,
Whats the transfer time for an 8GB P2 card when using the laptop/fw/external drive combo?
Sam
