Activity Forums Square Box CatDV Is this possible with sequences?
  • Is this possible with sequences?
    Posted by Trevor Asquerthian on February 13, 2016 at 6:02 pm
    I’m trying out CatDV as a cataloguing and browsing supplement to Avid & Premiere Pro editing. I have demo versions of Server / Worker node / Pegasus & all is setup and working fairly well.
    Can I do any/all of the following?
    1. Auto Stringout Sequence? e.g. all clips that start ABCD with creation date of XYZ in one stringout sequence (may have to have a choice of alphabetical by name or ascending timecode but we are mostly time of day), either in Pegasus or as a Worker node. Currently I’m doing it by using quick filter and sorting by name.
    2. Match frame within a sequence to get back to the source clip? (e.g. I have manually created stringout and shuttle around it to find a shot – I can’t see any easy way to identify source clip/source timecode.
    3. As an alternative – an option to overlay source clip name & timecode on a sequence? (i.e. not burnt in, a dynamically generated overlay)
    Obviously a workaround is to create proxies with burnin and use those, but this job I’m trying it out on has way too much material for that!
    Thanks for any help
    Trevor Asquerthian replied 10 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
