Activity › Forums › Adobe After Effects › Is this possible in after effects?
  • Is this possible in after effects?
    Posted by Chad Vigar on November 5, 2020 at 3:12 am
    Ok, so i have stationery camera on a tripod with a black background and a dancer moving across frame. The dancer is lit up like a rainbow using an off camera stage light setup.
    What i am trying to do in after effects is have the dancer move normally from end frame to end frame but have the light that is reflecting from her body leave a trail on the background.
    Can this be done in after effects and if yes how?
    P.S. echo seems to leave to much of the dancers structure when i am only after the light trail.
    Thank you in advance.
    Brendon Murphy replied 5 years, 10 months ago 3 Members · 2 Replies
  • Graham Quince
    November 14, 2020 at 2:59 pm
    Try pre-composing a copy of the dancer so that you add colour correction effects and blurs. Then apply the echo to this. It should be a lot less solid.
  • Brendon Murphy
    November 14, 2020 at 4:12 pm
    you can also use blending modes on the precomposed layer. Something like “screen” will leave only the bright parts of the image. You can use a levels or curves effect to crush the shadows and get rid of everything except the projections.
