Activity Forums VEGAS Pro Is this possible…
  • Is this possible…
    Posted by Scott Morrison on March 14, 2010 at 4:48 pm
    I’d like to know if it’s possible to write a script that searched video clips for a specific occurance of a “black box” for example?
    Here’s my problem…I have a large recorded avi which has many occurances where an annoying black box show up with the message “buffering content” (for various lengths of time).
    Rather than using a script look for the audio silence gaps, I’d rather look through each frame of video for the black box message. The reason is, I don’t want to clip areas where the silence is warranted. Only the case where the silence is due to the bufffering.
    I’m sure this is a tough one, but any thoughts on the matter would be very appreciated.
    Scott
    Scott Morrison
    Just an amateur trying to learn
    Mark Greenwood replied 16 years, 5 months ago 2 Members · 1 Reply
  • Mark Greenwood
    March 15, 2010 at 11:36 pm
    Can I just confirm that the black box message to which you refer is something outside of vegas. E.G. the actual media itself has these areas?
    The only way I think to script this would be to run through each frame of the video – take a snapshot and then compare it to an image you already had – that would be one idea – which would of course take a HUGE amount of time – but is at least doable.
    Ideally you’d actually do this in C++ so you could process the frames on the fly – but that’s a fair amount of work.
