Activity Forums Apple Final Cut Pro Legacy Is this possible….
  • Is this possible….
    Posted by Sarecco on August 22, 2007 at 1:45 pm
    Is it possible to convert a 4 bay external SCSI enclosure to accept 4 SATA drives? (I’ve had the enclosure for about 7 years. Very expensive) I got all 4 SATA drives to mount & power up in the enclosure. Just not sure how to cable/raid them to the Mac 3.0 dual quad computer. Is there a kit? What would I have to purchase?
    Steve
    Steve from NY
    Paul Dickin replied 19 years, 1 month ago 3 Members · 2 Replies
  • David Bogie
    August 22, 2007 at 10:15 pm
    Probably not but contact the maker of the enclosure.
    SATA and SCSI are totally different drive interface and data systems with different power supplies and connectors and handler cards.
    bogiesan
  • Paul Dickin
    August 23, 2007 at 10:14 am
    Hi
    I’ve done this for an older PCI-X G5. But it was angle-grinder time 😉
    The Mac has an eight-port Sonnet Tempo 8 eSATA card in it, and the external box has ordinary PCI-slot-cover SATA external port-replicator sockets chopped down to fit in the SCSI openings in the back of the box.
    Inside the box there is a short SATA cable that goes to each drive from the socket, and an SATA>eSATA 1 metre cable connects the socket on the back to the Sonnet card.
    The 8-channel cable bunch is a sight to behold, but the drive box is mounted directly under the computer, and the cables bunched together and tied back.
    Inside the drive box I fitted a couple of 6-drive Intel Server hot-swap caddy SATA drive cages, which gives drive swapability without cable fiddling.
    Also lovely twinkly green activity LEDs on the front panel – just like a proper drive bay 😉
    As an aside its far easier converting a SCSI box to FW800, as you can get FW800 bridge boards that exactly fit in the SCSI openings.
