Activity Forums VEGAS Pro Is this normal?
  • Is this normal?
    Posted by Paul Gregory on May 8, 2005 at 2:36 am
    Most times when I open Vegas 5.0d I get the last worked on project displayed & everything appears to be the same as when I logged off exect that the preview window has gone. Most times I have to go & open it again. Why should this be?
    Another thing is that I also freqently get the message that the program had been incorrectly been shut down. I always select the restored version on offer & compare it to the last version that I saved & never once have I ever been able to see any difference between the two. Is his normal?
    Edward Troxel replied 21 years, 3 months ago 3 Members · 3 Replies
  • Edward Troxel
    May 8, 2005 at 3:04 am
    I have not noticed either of those happening. I have also turned OFF the “automatically open project” option so it never opens a project upon start unless I have managed to crash Vegas (or, more likely, the power went off).
    Edward Troxel
    JETDV Scripts
  • Michael Legel
    May 9, 2005 at 5:56 pm
    Hello Edward,
    Do you turn that off in preferences? I have always found the automatic start a little bit annoying but not enough to dig through preferences to find it.
    Is there a similar off switch in DVD Architect?
    Thanks for the information.
  • Edward Troxel
    May 9, 2005 at 7:42 pm
    Yes, I have that option turned off in the preferences in both Vegas and DVDA.
    Edward Troxel
    JETDV Scripts
