Activity Forums Adobe Premiere Pro is this machine capable of HD editing?
  • is this machine capable of HD editing?
    Posted by Kevin Sebastianpillai on April 4, 2010 at 10:39 pm
    Hi guys
    I’m a video editor in London and am finding that my current system struggles with HD projects in Premiere CS4.
    It’s a Dell, specs are:
    Intel Core2 Quad 2.33GHz (Q8200)
    Dell 0M017G motherboard
    3GB memory (DDR2, PC2-6400)
    Vista Home Premium 32-bit
    ATI Radeon HD 3650 256MB graphics card
    1x WD Caviar 500 GB hard drive (SATA, 16MB Cache, 7200 RPM – Model: WD5000AAKS)
    Can anyone recommend upgrades that’ll improve performance? Namely less stuttery playback and better rending!
    Many Thanks
    Kevin
    Kevin Sebastianpillai replied 16 years, 5 months ago 5 Members · 6 Replies
  • Bill Clark
    April 5, 2010 at 6:36 am
    In my experience its either the OS or the RAM. The trouble with windows is that it is limiting on RAM. And I think Vista is awful. We still run XP pro SP3 on a XW8600 and everything runs fine – AE and AVID both at HD res. But we keep the programs open down. Try swapping to XP pro or upgrading the Vista to 7 premium. That’s supposed to be better. I believe you can get more RAM in with Windows 64 bit but I’m a bit out of touch. Mostly we use MacPros for everything now.
    Bill Clark
    Origami Films
    http://www.origamifilms.com
  • Jeff Pulera
    April 5, 2010 at 11:52 am
    Hi Kevin,
    If you can, install a second internal SATA drive and keep all your video files and projects there; using the C: drive can hurt performance since Windows needs to constantly access the drive.
    Jeff Pulera
  • Kevin Sebastianpillai
    April 5, 2010 at 12:34 pm
    Hi Guys
    Many thanks for that. I will add a 2nd SATA drive, sounds like an affordable solution. RAID sounds pricey and tricky.
    I will also put in more memory and do a dual boot with Windows 7 64-bit to utilise it.
    Couple of other things…
    – my 2.33Ghz quad core…you reckon it’s not great bang for buck upgrading this? The newer quad core chips ain’t cheap let alone an i7
    – GFX card: my ATI Radeon 3650 with only 256MB…is it worth considering a swap to nvidia? Am thinking in terms of stability as well as performance
    Kevin
  • Brian Louis
    April 5, 2010 at 4:20 pm
    [Kevin Sebastianpillai] ” my 2.33Ghz quad core…you reckon it’s not great bang for buck upgrading this? The newer quad core chips ain’t cheap let alone an i7″
    To get any significant boost you would need to goto a 2.8 or 3 gig processor (20-25%)($250-$300) without going to a i7 which would intail a new mobo and memory also, you could probably overclock your current processor abit if your mobo could handle it and squeeze 10-15% out of it with no problems.
  • Bob Dix
    April 8, 2010 at 5:22 am
    Your set up exceeds CS4 specs, I am surprised you have a problem.We have problems with MOV. H.264 files 1920 x 1080p about 25 mb for 4 secs. But, when opened in Premiere Elements and Exported to Movie as avi files and re-imported to Premiere Pro, it may be slow to render but, the result is very smooth Exported to Tape. Anyhow, they tell me CS5 is out soon to solve all problems in Premiere, as I believe many of the problems are there
    Freelance Imaging & Video
    AUSTRALIA
    April 8, 2010 at 8:11 am
    Thanks for all the replies guys…the way forward for me is an additional hard drive, new OS and more RAM.
    RAID and a new chip are sadly too pricey/fiddly I think.
    Best
