Activity › Forums › Adobe After Effects › Is this green screen or studio lighting?
Posted by Deke Ryland on June 13, 2008 at 1:38 pmI love the background Scott Kelby used for this video, but was wondering if he used a studio background with lighting, or if he just shot this on green screen and made the background in photoshop. Anyone have any guesses?
https://www.youtube.com/watch?v=YOpoMS6YT54&eurl=https://www.scottkelby.com/blog/page/5
Jeremy Allen replied 18 years, 3 months ago 6 Members · 5 Replies -
Christian Wheel
June 13, 2008 at 1:52 pmI would say green screen, if you look closely you can very faintly see the edges (although it COULD be compression artifacts), but he’s also not casting shadows on the backdrop, which is inconstistent with the direction of his lighting. Finally, when the video cuts to tight shots, the backdrop resize appears slightly disproportionate from how it should.
Again, just a guess, I could be way off base!
Akber Moeen
June 13, 2008 at 3:02 pmYeah sure its a green screen stuff, if you can see carefully his head part in closeup u can see a green spill at the top of his head for a while in one of the closeup shots, that where i caught that this is green screen job.
Jeremy Fabiano
June 13, 2008 at 3:06 pmI can’t tell.. Either way would work
if you did your chroma screen the right way, it should look just like the studio setup
-Jeremy
Erik Pontius
June 13, 2008 at 3:55 pmMy money is on a simple studio lighting setup. Most likely a light with a party gel lighting a black, gray or colored cyc wall or seamless paper behind the subject creating a wash with a bit of a hotspot.
This could be done green screen as well, but why spend the extra time and effort properly lighting a green screen and pulling the matte when a five minute lighting job can do the trick?Erik
Jeremy Allen
June 13, 2008 at 7:10 pmI think I agree with Akber. It looks like green spill on his hair, although I guess it could be a lighting anomoly. But it could certainly be done easily with a simple lighting setup.
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2
DualCore G5 2.0 GHZ, 2GB RAM, OSX 10.4.11AE7 on both for now.
