Activity › Forums › Apple Final Cut Pro Legacy › Is this external drive adequate to edit from directly?
  • Is this external drive adequate to edit from directly?
    Posted by Mark Suszko on August 14, 2012 at 2:52 pm
    Sam’s Club was blowing out these 2-terabyte external drives for a hundred bucks. I got one initially for just a backup archival use, but I wonder if I can edit FCP projects using it as a scratch drive, feeding my new imac via usb3.
    It’s a Seagate free agent go flex 2 TB. No specs are listed. Thoughts?
    Mark Suszko replied 14 years, 1 month ago 3 Members · 3 Replies
  • Steven Cohen
    August 14, 2012 at 3:08 pm
    If it is this one..
    https://www.amazon.com/Seagate-FreeAgent-GoFlex-External-STAC2000100/dp/B003ELOSJG
    Then most likely it is not going to be able to edit directly.
    It is just a USB 2.0 connection which won’t handle the data transfer needed to edit, especially if you are doing any HD.
    Steve.
  • Shane Ross
    August 14, 2012 at 3:29 pm
    I think they need to list their specs! Even on the website they don’t list the speed of the drive. Because of this, I suspect that they are putting in 5400RPM drives, and touting these only as backup.
    But try it out and see. I too am looking for a USB 3 drive to test using as a media drive.
    Shane
    Little Frog Post
  • Mark Suszko
    August 14, 2012 at 4:10 pm
    It touts a USB 3 connector, which is what got me thinking about it as a scratch drive… for non-critical home movie type usage.
