Activity Forums Adobe Premiere Pro Is this even possible?
  • Is this even possible?
    Posted by Bailey Edenburn on May 10, 2018 at 6:28 pm
    Ok, so upfront, I’ve never worked in premiere pro. I do want to know if it would be possible to do something in premiere. I edit livestock sale videos and we put things like birth weight in the video, however, those numbers can change weekly (ex: https://vimeo.com/258195857). Would there be a way to build a layer within premiere that I can then just export data to from say an excel spreadsheet? Basically I’m looking for a quick way to update the video without having to rebuild the background template.
    Thank you for any input.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Joe Bender replied 8 years, 3 months ago 4 Members · 3 Replies
  • Blaise Douros
    May 10, 2018 at 9:20 pm
    No, that’s not possible. You’ll need to make changes manually. Just duplicate the sequence, and then copy-paste the new values from your spreadsheet into whatever title text you’ve built.
  • Scott Fleener
    May 16, 2018 at 10:22 pm
    Unfortunately From what I researched its not
  • Joe Bender
    May 31, 2018 at 9:11 pm
    You can probably do at least part of this using a method I use to generate subtitles with a utility called psTitles by Andreas Kiel: https://www.spherico.com/filmtools/TitleExchange/psTiltles/index.html
    You can create a spreadsheet with three columns, Timecode In, Timecode Out, and Contents. Then you export the spreadsheet as a CSV file, rename it to .stl, and use psTitles to generate TIFF files according to a template. psTitles also exports an XML sequence file. When you import the XML into Premiere, your titles are laid out in a timeline with the appropriate in/out/duration. You can then copy/paste those subs over your edit.
    I don’t think it’s exactly what you’re looking for, but it lets you quickly generate and import a large number of text items from a spreadsheet.
    Hope that helps!
