Activity › Forums › Adobe Premiere Pro › Is this enough Memory
  • Is this enough Memory
    Posted by William Mcqueen on July 31, 2010 at 4:40 am
    Here is what a guy who will build my new system suggests…
    5 661 vpro Processor
    Asus MotherBoard
    4gb DDR3 Memory
    500Gb Sata Hard drive
    Mid Blk Case
    500Watt
    Dvd Burner Sata
    Windows 7 home Premium 64bit
    Can you run both CS4 PP and CS4 After Effects with this amount of memory. I will add a second drive as the scratch drive…any suggestions…thanks.
    Bill in Toronto
    Bob Dix replied 16 years, 1 month ago 4 Members · 3 Replies
  • Brian Louis
    July 31, 2010 at 10:16 am
    If you are going to multi-task you want 6gigs bare minimum, 8gigs or more is better, Ppro CS4 can use up to 4gigs by itself.
  • Ann Bens
    July 31, 2010 at 12:46 pm
    I would go for 12.
    And you need at least two seperate internal harddrives.
    On for OS and one or better two for the rest.
    https://help.adobe.com/en_US/PremierePro/4.0/WS369BD79A-5DF9-48d8-9F49-6B56026087C8.html
  • Bob Dix
    August 1, 2010 at 8:25 am
    A 1,000 GB would be better, our old computer worked on 400Gb but, you will need to get rid of temp files %temp% in Windows explorer window, that is to get rid of temp files easily, at one stage we had 1,443 rendered mov files there, not a good look, and then operating on a mere 15Gb, you cannot defragment which is esential with HD H264 mov files.
    Freelance Imaging & Video
    AUSTRALIA
    Ps Sorry, 1,000Gb hard Drive. Ram , well we got away with 2GB and it worked, but, now have 12GB RAM
