Activity Forums VEGAS Pro is this drive sufficient?
  • is this drive sufficient?
    Posted by Joe Tavola on June 17, 2012 at 4:47 pm
    need to get a second drive to render/store media for Vegas, is this Western Digital 750GB Internal Hard Drive (WD7500AZRX) – Green ok .. or should i stick with the Black editions? Any big difference? Seems like it has pretty good specs..
    Average Seek Time
    1 ms
    Data Buffer
    6 Gbps
    Interface
    SATA 6 Gb/s; SATA 3 Gb/s
    Maximum Data Transfer Rate
    600 Mbps
    PC/Mac
    PC and Mac
    Product Dimensions
    10.2 (W) x 14.7 (H) x 2.5 (D) cm
    Product Weight
    0.45 kg
    Rotations Per Minute (RPM)
    7200 RPM
    Storage Capacity
    750 GB
    Stephen Mann replied 14 years, 3 months ago 4 Members · 5 Replies
  • Mike Kujbida
    June 17, 2012 at 6:44 pm
    Stick with the Black edition as the Green ones will go to sleep on you – when you least expect it 🙂
  • Joe Tavola
    June 18, 2012 at 12:44 am
    thanks, ya i am skeptical on the Green versions.
  • Mike Kujbida
    June 18, 2012 at 12:56 am
    I use green drives but strictly as backup as they go to sleep after about 5 minutes.
  • Nigel O’neill
    June 19, 2012 at 12:53 pm
    Some green drives spin at a lower speed like 5400 rpm and I have seen some non-green drives spin at 5900 rpm. So long as the data transfer rate is unaffected, the slower spinning drives in theory should run cooler.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Stephen Mann
    June 20, 2012 at 4:20 am
    For what it’s worth, Microcenter has Barracuda 2TB drives on sale for $109 through Monday.
    I have about ten Barracuda drives in use here, some 1TB and some 2TB, and haven’t had a drive failure in ten years. (Every project gets it’s own drive and I just drop the drive into the external docking station and edit).
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
