Activity Forums Adobe After Effects Is this an example of compositions dynamically linked?
  • Is this an example of compositions dynamically linked?
    Posted by David Honan on January 9, 2015 at 11:13 am
    Hi from 18 mph winds and about to rain York UK 🙂
    https://i216.photobucket.com/albums/cc53/zymurgy_bucket/composition-crosslinking-afteraffects_zpse9c1ea28.jpg
    The above link illustrates my question but here goes:
    Having downloaded an after effects template It soon became apparent that the compositions were linked to each other. I didn’t know you could do this. For example in the template I downloaded there are three composition tabs (think thats what you call them). Ive noticed when I hide a layer (clicking on the eye ball icon for a specific layer) it affects another tab.
    So my question is please… “Ids this a case of compositions being dynamically linked within one project? And if wanted how could I switch off / break the link”
    Thanks in advance,
    David
    David Honan replied 11 years, 8 months ago 3 Members · 3 Replies
  • Walter Soyka
    January 9, 2015 at 11:46 am
    Dynamic link is the name for a set of technologies for moving the output from one Adobe application (like After Effects) into another (like Premiere) on the fly, without having to save a rendered file to disk.
    What you see in that template are nested compositions [link]. With a nested composition (or a precomposition or precomp for short), one comp becomes a source for another comp.
    If you want to break the link between a nested comp and a containing comp, you must duplicate the nested comp in the project panel and work with a copy.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Daniel Waldron
    January 9, 2015 at 5:22 pm
    You may want to duplicate the original nest and option+drag it onto the precomp you want to modify. However, be aware of precomps inside of precomps. Duplicating a precomposition does not automatically duplicate any nests/precomps inside that composition. In this case, the True Comp Duplicator script can come in handy.
  • David Honan
    January 13, 2015 at 5:43 pm
    Brill thanks 🙂
