Activity Forums Adobe Premiere Pro Is this a good editing system?
  • Is this a good editing system?
    Posted by Stacey Cruwys on May 20, 2008 at 6:47 pm
    I am looking to edit a feature length film shot on a Canon XH-A1 in 30i HDV and would like to purchase a new system to edit it on. I saw on the Adobe site that they have certified the HP xw4600 to use and I wondered if this was a good option for $1699. I will be using Premiere Pro 2.0 or maybe CD3 and I think Aspect HD.
    HP xw4600(RB431UT)
    Recommended Usage Business Desktops & Workstations
    Form Factor Convertible Minitower
    Processor Intel Core 2 Quad Q6600(2.4GHz)
    Processor Main Features 64 bit Quad-Core Processor
    Cache Per Processor 2 x 4MB L2 Cache
    Memory 4GB DDR2 800
    Hard Drive 250GB 7200rpm SATA 3.0-Gb/s NCQ
    Optical Drive 1 16X DVD+/-RW SuperMulti SATA
    Graphics NVIDIA Quadro FX1700 (512 MB)
    Audio Sound card – Integrated
    Ethernet Gigabit LAN
    Power Supply 475 watts wide-ranging, active Power Factor Correction, 80 PLUS Efficient
    Operating System Windows Vista Business / XP Professional downgrade
    Chipset Intel X38 Express
    CPU Type Core 2 Quad Installed Qty 1
    CPU FSB 1066MHz CPU Speed Q6600(2.40GHz)
    L2 Cache Per CPU 2 x 4MB
    CPU Socket Type LGA 775
    CPU Main Features 64 bit Quad-Core Processor Graphics
    GPU/VPU Type NVIDIA Quadro FX1700
    Graphics Interface PCI Express x16
    Memory Capacity 4GB DDR2
    Memory Speed DDR2 800
    Form Factor DIMM 240-pin
    Memory Spec 1GB x 4
    Memory Slots (Available/Total) 0/4
    HD Capacity 250GB
    HD Interface SATA
    HD RPM 7200rpm
    HD Spec SATA 3.0-Gb/s NCQ
    Optical Drive Type DVD Super Multi
    Optical Drive Spec 16X DVD+/-RW SuperMulti SATA
    Audio Chipset Integrated
    LAN Chipset Integrated
    LAN Speed 10/100/1000Mbps
    Front Panel Ports
    Front USB 2
    Front Audio Ports 2
    Back Panel Ports
    COM 1
    LPT 1
    PS/2 2
    Rear USB 7
    eSATA 1
    RJ45 1 port
    Rear Audio Ports 3 ports
    Expansion
    External Bays 3 x 5.25″
    1 x 3.5″
    Internal Bays 2 x 3.5″
    I also have an external hard drive. I’d also need to install a firewire card and could also purchase an additional internal hard drive to install. I’ve also heard that the Dell T5400 is an option. I’m not sure which is better for the money.
    The last movie I shot I was able to edit on my home computer since it was DV. i’ve done a lot of research but am still not quite sure of the exact specifications that I should be looking for. I want to buy what’s easiest (I’m not sure about custom configurations) as well as a good value for the money. Any help you can give me would be much appreciated.
    Stacey
    Jiri Fiala replied 18 years, 3 months ago 4 Members · 5 Replies
  • Perry Cheng
    May 20, 2008 at 9:32 pm
    I think that is too pricy myself. I built my own with similar setup with 1/2 the price. I think upgrading to CS3 is probably a good idea also.
    Perry
  • Stacey Cruwys
    May 20, 2008 at 9:44 pm
    Thanks. Building my own isn’t really an option. I’d basically like to know if the computer I mention would be good enough to edit HDV with Premiere.
  • Perry Cheng
    May 20, 2008 at 10:47 pm
    I think it is pretty decent.
    Perry
  • David Dobson
    May 20, 2008 at 11:16 pm
    More than good enough. Definitely upgrade to CS3.
  • Jiri Fiala
    May 22, 2008 at 10:25 am
    I would definitely consider buying Cineform though, it REALLY makes things fly with HDV and Adobe apps.
