Activity Forums Apple Final Cut Pro Legacy Is this a benefit of ProRes?
  • Is this a benefit of ProRes?
    Posted by Ron Craig on April 9, 2008 at 12:55 am
    We had a string here a couple of days ago in which David Roth Weiss was educating me about the benefits of ProRes. (Thanks, David.)
    One of the benefits of ProRes is that it is 10-bit (vs 8-bit for, say, Firestore date). But here is my question:
    The videographer I work with shoots a Panasonic HDX900 (DVCPRO HD tape). The specs for that camera say that the circuits record the image at 14 bits. But the specs also say that the videotape recorder is recording that data at 8 bits.
    So if the tape is recorded at 8 bits, what benefit do I get out of capturing it to ProRes at 10 bits through Kona 3? The source material is what determines the picture resolution, color depth, etc., right?
    One reason I ask this is that I am trying to determine whether I can be making more use of Firestore data. I had thought the Firestore might be inferior, measured by the 8-bit vs 10 bit. But now I’m not sure.
    Would appreciate any educated information about this.
    Rennie Klymyk replied 18 years, 5 months ago 10 Members · 12 Replies
  • 12 Replies
  • Jerry Hofmann
    April 9, 2008 at 1:15 am
    DVCPROHD is an 8 bit codec alright, but where you’d benefit is with graphics or stills not captured via video but CGI created. They would all be rendered in 10 bit. You’ll not improve the video per se, but will improve everything else you add to that ProRes Sequence, especially graphics/titles with gradients.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jeremy Garchow
    April 9, 2008 at 1:19 am
    [Ron Craig] “The specs for that camera say that the circuits record the image at 14 bits. But the specs also say that the videotape recorder is recording that data at 8 bits. “
    Correct. That means the a/d process (taking the analog signal off of the chip and turning it to digital) processes at 14bits, then gets knocked down to 8 for tape compression.
    [Ron Craig] “So if the tape is recorded at 8 bits, what benefit do I get out of capturing it to ProRes at 10 bits through Kona 3? “
    All graphics and CC will get the benefit of 10 bit rendering, meaning less loss and smoother gradients. An overall ‘cleaner’ signal. It won’t benefit your footage too much (won’t hurt it either), it will benefit everything you do and add after it.
    Jeremy
  • Ron Craig
    April 9, 2008 at 1:29 am
    Thanks, gents.
  • David Roth weiss
    April 9, 2008 at 5:01 am
    [Jerry Hofmann] “You’ll not improve the video per se, but will improve everything else you add to that ProRes Sequence, especially graphics/titles with gradients.”
    Yes, that’s what I said, but I added that there would be less generational loss in the video, especially noise and banding in flat areas such as skies.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Adam Taylor
    April 9, 2008 at 8:13 am
    won’t those extra 2 bits also give you a little more latitude when you send the video through Color?
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
  • Devin Crane
    April 9, 2008 at 12:26 pm
    Pro Rez is great but if you are capturing in DVCPro HD and Delivering in DVCPro HD you might as well stay in DVCPro HD you will not gain a thing going over to Pro Res other than render times and a little loss since you are having to do extra compressions. If you capture a native format and deliver on a native format better to stay that route you won’t gain a thing.
  • Jerry Hofmann
    April 9, 2008 at 1:14 pm
    Um, not true completely… Graphics, photos, psd’s etc will all benefit from working in 10 bit sequences.
    I don’t think that upconverting the DVCPROHD will improve the ability to grade it in Color though… the “damage” was done when you shot it in the first place.. not dissing the camera.. it’s great, but it’s only 8 bit, and you can’t add color information that wasn’t shot in the first place. You won’t hurt it either transcoding it to ProRes… course, the cost of this is disk space… ProRes is about twice the size file as DVCPROHD at the same frame rate.
    Jerry
  • Devin Crane
    April 9, 2008 at 1:48 pm
    What are you gaining though if you are going to recompress it in 8 bit DVCPro HD again after you compressed it in Pro Rez? Is it really that big of a difference? Yes the graphics will look nicer in Pro Res but what about after compress it again in DVCPro HD?
    If this was HDV I can see the point of it, but working in DVCPro HD thats a different story.
  • Gary Adcock
    April 9, 2008 at 2:01 pm
    [Ron Craig] ” So if the tape is recorded at 8 bits, what benefit do I get out of capturing it to ProRes at 10 bits through Kona 3? The source material is what determines the picture resolution, color depth, etc., right? “
    First off – ALL cameras record 8bit content internally on tape. A/D imagers in the cameras are designed to do only one thing – that is compress the Analog light data into the 8bit (256 levels of gray per color channel or about 66,000 unique colors at one time)
    However, in Post – whether compositing or color correcting it is far more advantageous to be able to allow the data to move about in a slightly larger “working area” available in the vastly larger 10bit color space ( with 1024 levels of gray or 1,048,576 colors at one time)
    so more data can be handled without sacrificing picture quality
    So
    do you want to work in a tight cramped space – or have the room to do all that you need to do.? Granted not everyone needs to work in 10bit. Working on a project with cuts only edit and no color correction for has no need to “HAVE” to work in 10bits, 8 is more than enough.
    Many, many people are very happy with the 8bit DVCPROHD workflow, but if you are doing a fair amount of image processing in your projects – ProRes is the way to go.
    FYI- I am finishing a pretty technical paper on ProRes that will be released after NAB- I think there are some things about ProRes everyone needs to know.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Martin Baker
    April 9, 2008 at 4:11 pm
    If you’re outputting to a 10 bit format then it makes complete sense to me that you’re going to get finer control when grading etc. But what I’ve never been able to get my head around is how an 8bit/10bit/8bit workflow can provide the same advantage.
    If you output at 8 bit, then the pixel values can only be what’s available. So wouldn’t all those smooth gradients you get at 10 bit get lost when crushed back into 8 bit? Or am I missing something fundamental here?
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
